High Guys
Just found you!
Hope you can help.
There is a problem with the delivery of oil to the tank under the cowl from the one in the Hull
I have removed the hull tank and ran 12 volts through the pump
I made a noise as if it was pumping but no oil came out
I only ran it for about 5 seconds in case I blew summat!!
Twice I have had to top up the 'upper' tank after the boat went into limp home mode and a continuos alarm went off.
Can I do a better test of the hull tank?
What can I test at the engine tank end?
Thanks in advance
K
Just found you!
Hope you can help.
Thanks in advance
K
