I have a pair of 2004 F225s. Last trip out I could not get one of them to increase RPM beyond 4900 when the other engine would go to 5300. The last 25% of throttle motion produced no change in RPM BUT it did produce a change in fuel consumption. With both engines at full throttle one was running 5300 RPM and 14 GPH and the other ran 4900 RPM and 16 GPH. My best guess is its running rich due to a problem with the TPS. Some other useful background information: (1) boat was struck by lightning, both ECU's are new. (2) TPS were not replaced after lightning strike (3) I have the YDS cable+software so can do advanced diagnostics if needed. (4) at less than 4500 RPM fuel use on both is the same. (5) I have verified the fuel management meters are accurate in that fuel burned according to guage == what I add to fill the tanks.
Am I on the right track or should I be looking elsewhere? Whats normal GPH for WOT?
Thanks in Advance,
Chris
Thanks in Advance,
Chris
