1992 C85 tiller to remote conversion
  • 1992 C85 tiller to remote conversion
    Hi, I have a 1992 C85 Yamaha set up with a jet unit and I'm wanting to convert it to a center console. I've purchased a used 703 10pin control box (I believe it's a 1995 control box). I'm trying to figure out what other parts I will need to finish the installation. I know that the shift cables will need to be a couple of feet longer than the throttle cable, but what I'm unsure about is what I will need for the electrical, choke, throttle, etc... connections?
    Thanks,
    Chris
    If your motor has the the 10 pin wire harness connector on it then it will connect to 703 control box harness, otherwise will need to replace electrical harness on engine to one with a 10 pin connector.
      Thanks!
      I appreciate the help!
