Hello all, I am new to this site and really appreciate any info you can give me before I haul my boat to the shop.
I have a 1999 Yamaha F100 outboard. The problem I am having is with the trim and tilt assembly. The motor will go up just fine but when I go to the put the motor down, It seems to lock up. I then have to "jog" the motor up slightly. The motor then goes down just fine. If I have the motor in the full up position, it will not go down at all since I am not able to put the motor up a little first. I then have to use the manual release to lower the motor slightly which it then works ok.
I was told by one shop that it is a faulty seal within the assembly and im lookin at about $200 to have them fix it. Any suggestions? Thank you.
