Y-cop
  • Y-cop
    Hi there, I am new to this forum thing but i need help!!! I have a new F30 2010 and i have the Y-COP system and i cant work out how to fit it???
    Can any one help please?
    Is this USA motor? the F30 has not been available for a few years and according to chart I have it's not YCOP compatable.
      ycop
      no it is not a usa motor i am in spain! and the ycop comes as standard with the 30hp and 40hp over here! I just cant see how it all plugs togeather!
        It connects to the Command Link network hub, if you do not have Command Link gauges installed then you would need a CL hub and main Bus lead installed.
        If you do have Command Link gauges then disconnect battery cable, install YCOP and connect to hub, make sure ignition key is off and reconnect battery cable and engine ECU will sync with YCOP.
          Thank you very much for your help!
          Now i can see what i have to do!
          Thanks again
          Sam.
