F75 current year.
What size motor mount holes should I drill in the transom, to line up the motor mount holes on the bracket?
Do these bolts need a "sleeve" inserted in the drilled holes and if so, then what would the bolt diameter be?
Should a plate of aluminum or other material be used like a "fender" washer on the inside of the transom, where the nuts would be....to "spread" the torque of the nuts?
Transom is glass over ply 2.25" thick.
