I just installed twin 150 HPDI'S, used. I went to start them today> the stbd motor started great. Went to give it gas, it bogged like it wasn't getting enough fuel. Stalled, started, same thing. Went to start it again, all I get is a click.....HELP!!!!!!!!!!I can also be reached at lmh229@hotmail.com
01 150 HPDI Problem
Check all battery cable connections are clean and tight, load test battery to make sure ok.
Those engines have to have 10 volts at engine to run, the HPDI models have a overrev in neutral feature so if you are tring to rev up while in neutral it will limit the rpm's.
Check compression, fuel pressure and fire at spark plugs.
Yes that have the speedo pickup in gearcase, should be a small hose in cowling that is connected to gearcase that you can connect your speedo hose to.
Yes you can install one on transom and connect speedo tubing from gauge to transom mounted pickup.
Thank you so much for replying. I can finally finish the boat from hell!!!, I should say the owner, not the boat
