2017 F150XB oil change
  • 2017 F150XB oil change
    What procedure would you recommend for changing oil , oil extractor pump or drain plug?
    thanks
    The Yamaha factory Service Manual lists both, as equally acceptable.
    For me, the difference is:
    no one ever stripped out an oil pan drain plug, extracting the oil through the dipstick.
      I use the drain plug but torque to 12' lbs (same as the filter)
      I use the Seewell "Tilt and Drain" oil drain kit: https://www.ebay.com/c/1573702297 .
      You tilt the engine all the way up. Remove the drain plug (no oil comes out) and screw in the plastic threaded end which is connected
      to a plastic hose.
      Put the end of the hose into your "catch container", trim down and all the oil comes out. Siphoning leaves maybe 3/4 a cup of oil in the crankcase (not much).
      I found this method cleaner and faster.
        Try both, and see what you prefer.. that's what it really comes down to: personal preference. Extracting is probably the most fool-proof way. Good extractors aren't cheap, but they're good to have for other unexpected jobs that might come up (like overfilling the oil or fuel tank). I started out using an extractor, but now I drain it because it's faster and I have a torque wrench.
        2011 F50TLR, 2010 G3 V167C
