I have a 2005 Yamaha F150 with about 200hrs on it and last week when I put it in reverse it started to grind. I was out all day and the boat shifted fine in both fwd and reverse. Then it would not engage in reverse. I looked at the linkage and it seems to be shifting and engaging properly when the motor is off. When the motor is running it will shift and operate fine in fwd but will just grind in reverse. I had the lower unit oil, water pump, and other normal maint done a month ago with Yamaha parts. The motor is still under warranty, but last time I had a warranty repair for the cylinder head it took 3.5 months to get it finished.
1) What easy items could I check?
2) Where could I get a used lower unit in case I have to get it repaired and it takes a long time?
3) Is this a common problem?
Thanks,
Thanks,
