Hi all
I was wondering if there is a trick to pulling the powerhead off a 1991 200hp TXRP V6. I have all 10 bolts off per instructions in the manual but when i go to pull the PH off the front end of the PH seems stuck. Do i have to tilt the engine a bit to pull off or can i just horse it out of there. Does anybody have any suggestions or tricks that will work with out damaging the PH? Oh yeah i cant tilt my engine up because everything is un hooked. I tried the manual lift but it is stuck. thanks for any help you can give me.
matt
matt
