I have a 03' yamaha 150 TXRB, with teleflex anolog gauges. Recently tach has been going haywire. At idol it shows 3000rpm and when running it may show 7000, even though I know by sound and speed it may be around 2500-3000. Then it may start working again, but only for a little while. Also fuel gauge shows empty at idle, but moves up w/rpm's. how can I check to see if its the gauge or sending unit on motor?
tach problems
Check for 12 volts at yellow wire on tach and fuel gauge with key on and check grounds. If thats ok then probably a bad tach.
Thanks. I checked voltage, actually getting 12.8 volts. Ordered a new tach so hopefully thats the problem. will let u know.
ÂÂÂÂÂÂÂÂÂÂÂ
