Ah, he's got his engine in the KITCHEN!!
gearcase drain plug leak
leaky drain plug
If you like the cupboards, you'll love the boat the motor is on.
Leave a comment:
leaky drain plug
thats kinda what my "pea brain" thought. If the magnetic plug doesn't
arrive at the dealer by tomorrow, I'll have them install a new plain solid plug with a new gasket, making sure they follow the install instructions for the new style gasket. What an ordeal for just a simple service.
Leave a comment:
leaky drain plug
I think it went. see large photo above text "not getting the image moved over".
Leave a comment:
You posted a pic...
From that pic, sure looks like the plug itself is leaking from the center..
Leave a comment:
Originally posted by Tony Sopranzi View PostScott,
Can't seem to get the "hot link" to cut/paste over to my thread. I'm not
a whiz at this stuff. Something I obviously don't understand about this procedure.
Tony
Come back to an open post here, rt click paste, done!!
Leave a comment:
leaky drain plug
Scott,
Tony
Leave a comment:
Originally posted by panasonic View PostAnyone know why the text font is so bloody small on the replies...need a magnifying glass to read them.
Probably either a setting or that darn infection.
(Norton hasn't had to block anymore, but BOLD still doesn't work)..
Besides the broke bold, I can't change the font size (above the B, I, U, options..). That may be your issue...
Leave a comment:
Originally posted by Tony Sopranzi View PostOk - just did that Scott. Can RodBolt view them on the post image website
or am I to move them to our forum somehow
RB should be able to see that.
As stated earlier, the 19" setting makes the pic's the size I post...
Leave a comment:
Originally posted by panasonic View PostCommodore 64 with the cassette tape for memory...Haha
Took awhile to save about 10 lines of code.
Anybody remember the Wang computers? Not kidding....
Leave a comment:
As mentioned you need a flat surface on the gear case and a flat surface on the underside of the head of the screw.
The surfaces need to be parallel and this may well be difficult to achieve. I have seen this before on an outboard, extremely frustrating.
Any drilling for helicoil may not improve things and may well compromise this perfect fit.
The two need to be lapped together, which is very difficult to do with a threaded hole.
The only solution often is to glue them together. Not a problem with various sealers that can be snapped off and be cleaned away come next oil change.
Leave a comment:
Lots of home appliances had slotted screws with a small hole in the centre, screwdrivers were available to fit them, I guess it was the first attempts at high speed assembly, and before the philips head came into use that they were used.
Leave a comment:
Leave a comment:
