Does anyone know the RPM that the rev limiter kicks in on the zvF 115 SHO 2016 model? I know the max RPM is 6300 but am not sure when the limiter starts. Joe R
Rev limiter VF115 SHO ?
Do you know if the rev limiter will sound like a shutter box killing cylinders (misfire sound) or does sound normal but just won't rev past that point?
Joe R
the rev limiter is very subtle.
most folks don't even know they are on it. the motor just simply wont turn faster.
Only way for the ECU to limit RPMs would be to drop spark or fuel,
I would think if it did it to one cylinder(or more) steady it might cause problems to the motor, so I would believe it is random missfire of cylinders
ÂÂÂÂÂÂÂÂÂÂ
