Well I've had it out a couple of times and no oil. Cleaning the check ball seems to have done the trick. Don't know how long it will last but so far so good. Thanks to everyone that offered help and ideas.
2 stroke oil coming from carburetor (lots of it)
Similar problem
I have the same motor and had similar issues. I also had oil coming out of the carb cover. Also had excessive smoke after warm up and taking off from dock. Motor didn't run smooth then the excess oil cleaned out and ran fine the reset of the day. Found out that the manual fill switch (control assembly) by the main tank was stuck in the on position (manual fill). Replaced the control assembly and solved the problem. Runs like a dream.1985 Yamaha 115 #115ETLK6E5L35 on a Lund Cherokee
ÂÂ
