Originally posted by Captn Dave
View Post
Spark Plug Torque--Not By Hand!
Put the plugs in, tighten them, go boating.Originally posted by pstephens46 View PostWhat are the engineering thoughts on this taper versus "square" seat?
The end!
Leave a comment:
What are the engineering thoughts on this taper versus "square" seat?Originally posted by calif-victim View PostWas the topic of a crush gasket seat plug and a taper seat plug brought up??
That could be where the confusion is coming in.
Leave a comment:
Leave a comment:
Makes you wonder if CS got hammered by the storms,
where was he living anyway
Leave a comment:
LOL, love the net, and CS.....
Heck plugs are cheap and NEW ones DO make a difference...
R&R, snug down, DONE!
Leave a comment:
Don't forget to stick them in Drano...and put a video on YouTube.
Leave a comment:
My 2nd on this!....My 1999 C90 Yamaha still has the original plugs...I remove them about twice a year, sand-blast them clean and white, clean threads with a wire brush, a drop of oil on threads, replace by hand and tighten nice and snug without a torque wrench....no problems so far....it ain't brain surgery!!!Originally posted by Captn Dave View PostPut the plugs in, tighten them, and go boating.
Leave a comment:
Thanks for the feedback guys.
I'm guessing that since my heads threads are "fouled" with grease from both the dealer mechanic and me repeating this bad habit, going forward I'm going to forget the torque wrench way of installing plugs and resort to fractions of a turn past finger tight as described elsewhere i their thread. Ie 1/2-2/3 turn and call it good regardless of torque value.
Leave a comment:
Your links don't work..Originally posted by noclutch View PostEngine - F300, 350 hours
Last night when replacing mine ( because I'd de-carbed/shock treated) I found that the dealer had greased the threads of the old plugs, and they came out with what seemed like 10 nm of torque max.
I followed the owners manual torque recommendation and used a little grease (and there was left over grease on the head threads), but became uneasy with how much twisting it took to get to 28nm or 20 ft/lbs. I stopped a bit before that number.... say 20 -25 mm with grease...
So the question from the noob here, since I apparently over toqured them to a degree, and
I'm sure the crush washers are totally flat now and they're overtorqued. What should I do?
Replace the plugs with dry threads and barely torque? Loosen and do the "1/12 turn past finger tight" as per manual? I do remember the day when replacing plug washers after cleaning the plugs was commonplace, but times have changed. LOL
Per my F150 shop manual, it doesn't call for any anti seize.
Greasing threads also changes the actual TORQUE VALUE your applying... It'd be higher WITH grease..
Per NGK:
https://www.ngksparkplugs.com/about-...ut-spark-plugs
Leave a comment:
This thread was from almost a year ago. If you were to start a new thread with your question you will get more responses.Originally posted by noclutch View PostEngine - F300, 350 hours
Pix of old plugs and top of piston as seen through plug hole.
https://drive.google.com/open?id=0Bx...lpBbHp2QjhMc2s
https://drive.google.com/open?id=0Bx...nJzdFNIQzR3LUk
Personally I don't grease spark plug threads. I used to apply that same rule of thumb of tightening by hand. Then one time I needed to replace plugs I also had a torque wrench handy, so I used it to test that rule of thumb. Found it to be way under the spec lb-ft torque listed in my yamaha manual. Some people replace the crush washers, others do not like myself. I've never tested the compression pre and post crush washer application, though my engine runs the same either or.
Leave a comment:
Cross post fromTHT- opinions please
Leave a comment:
This i can confirm. I installed new plugs after purchasing my engine. Few months later I noticed a brown oily discharge coming from the spark plug ports. I attributed this to 2 factors...the spark plugs were not seated tight enough (despite the hand tight then wrench snug technique), and second the high amount of idle time.Originally posted by 99yam40 View PostSeems like I remember oil seepage around plugs before on 2 strokes.
I do not believe you would need to worry about leaking compression thou
No oily discharge has been seen since I tightened down plugs another 1/2 turn in, and the engines idle time has not changed since then. Which kinda brings this thread back full circle. Seating plugs to specified torque is worth practicing.
Leave a comment:
Leave a comment:
