I was getting ready to take out the boat last night and accidentally grab my gear lube and added it to my two stroke reservoir. I added maybe a shot glass worth into the reservoir. I still would rather drain it and start over. Looking at the diaphragm (2005 50TLRD Yamaha Outboard OIL PUMP Diagram and Parts) which number hose should I disconnect to drain it?
Draining 05 50TLRD 2-stroke res
One of the hoses is basically vent. The other one goes to your injection pump - remove that one, ideally at the pump (just in case any of the heavier oil made it's way into the hose - although I think that's being a little nit-picky).
But, since you didn't run it, you could also just suck out the oil from the tank. Considering how little gear lube you put in there to begin with, sucking out should more than suffice.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by Justinbrow56 View PostI was getting ready to take out the boat last night and accidentally grab my gear lube and added it to my two stroke reservoir. I added maybe a shot glass worth into the reservoir. I still would rather drain it and start over. Looking at the diaphragm (2005 50TLRD Yamaha Outboard OIL PUMP Diagram and Parts) which number hose should I disconnect to drain it?Chuck,
I was personally thinking hose 39, doesnt look hard to get to.
I also thought about removing it and cleaning it. I dont have much experience with outboards, this is my first boat. Just the two bolts and it should pull away. My one concern is when I start to detach all the hoses on the reservoir will I have oil coming out everywhere?
If not, your going to have to bleed, run premix for awhile, etc..
IMO, R&Ring the tank, way too much trouble for a very simple fix..Scott
Originally posted by TownsendsFJR1300 View PostAgreed ^^^^. just suck out what's in there.
Now what's the viscosity of the gear oil vs. the two stroke oil. Do you drain from the top or the bottom, what will be residual at the end?
IMO, do what I say to be sure.Chuck,
Originally posted by cpostis View PostNot to argue, but this is so simple. A couple of bolts, one electrical connection, and a few hoses. Just don't let the hose that feeds the pump drain and you don't have to bleed and run on pre-mix.
stay away from or at least put down the adult drinks when filling the tank next time
If you want to just drain the tank (I do not recommend), remove hose # "2" in the lower diagram and let the tank gravity drain (You don't need any pump. If you wanted to use one you probably have a gear case pump for your lower unit you can use). You should do this if you decide to remove the tank anyway as well.
If you decide to remove, clean, and flush the tank (my recommendation); perform the steps as outlined in the procedures. The line that feed your pump is # 17 in the top diagram, and # 4 in the lower diagram when you disconnect this, just keep upright, level, secure, and don't let drain. No biggy in my book. Installation is reverse order.
Might as well check/clean your strainer and check/replace your strainer gasket while you're doing this.
Chuck,
There's many ways to skin a cat, either will work..Scott
I think this is a "theory" vs "reality" thing. Often we tend to go overboard when fixing something. In theory, sure, remove it and flush it out. But in reality, sucking it out is MORE than enough. There's a few ounces TOPS of gear lube in there. No big deal. Can it hurt to remove and suck it out? Of course not. It's just not needed.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostI think this is a "theory" vs "reality" thing. Often we tend to go overboard when fixing something. In theory, sure, remove it and flush it out. But in reality, sucking it out is MORE than enough. There's a few ounces TOPS of gear lube in there. No big deal. Can it hurt to remove and suck it out? Of course not. It's just not needed.
But to me the difference in jobs is about five minutes for the drain the tank and 20-25 minutes to remove flush and reinstall the tank. Plus, any debris that may have accumulated in the tank over 11 years will be removed.
I guess I'm just more thorough. To each their own.
I can name that tune in ??? secondsChuck,
On Merc sterndrives, they use a remote, engine-mounted bottle for gear lube (granted, different beast than 2-cycle). I remove that bottle and clean it out every year, even though I don't know of any "printed" maintenance schedule that calls for it. But experience has shown me that the gear lube tends to get goopy and thick in the bottom of that bottle. Meaning, there's a possibility it could clog the hose that leads to the outdrive. Of course, this would only present a problem if there was a leak in the outdrive... BUT, it may keep the alarm from being triggered since the remote bottle may not "go down" on fluid as it should.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
ÂÂÂÂÂÂ
