Hi RodBolt, tried again at the weekend to get the 225 running,. This time I replaced the entire fuel line and a new hand pump, also removed the carbs and checked the reeds - all perfect. Engine still starts then stalls immediately, if i disconnect the yellow lead on the CDI it starts but only runs on the top two cylinders. If I crank the engine it sparks on all plugs. Any ideas? Thanks
Yamaha 225 2 stroke starting and running problems
Hi, I replaced the entire fuel line, removed the carbs and checked the reeds, they are like new and no problem. Same problem, the engine starts then immediately stops. If I disconnect the yellow wire below the cdi unit, the engine starts but only runs on cylinder 1 & 4. Any further advice guys? Thanks.
ÂÂ
