2004 V Max 150 HP Secondary Oil Pump that is mounted in the side of the main oil tank assembly questions.
I had posted last week that my low oil alarm went off while running at 5000 rpm for a extended period of time. I was able to fill the tank under the cowling using the toggle switch on back of the motor, under the cowling. I ran the rest of the day, and never had anymore issues.
I went out yesterday, and again, after fishing all day with no issues, and while running in at 5000 rpm's for an extended period of time, the low oil alarm went off again. This time, I was unable to fill tank under the cowling using the toggle switch.
I got home and pulled the oil tank, and removed the oil pump mounted in the side of the tank. There are two wires coming off the oil pump (-/+), one blue, one brown. I am not sure which is positive, which is negative. I would assume Blue +/ Brown -.
On most pumps, if you reverse the wiring, the pump will turn in the oposite direction.
My question is, if I connect this oil pump in reverse polarity (assuming Blue + / Brown - is correct), should the pump turn in opposite direction?
When connecting Brown to + / Blue -, the pump spins, but is not pumping oil (I would assume this is reverse polarity).
When I connect Blue + / Brown - (assuming correct polarity), the pump seems to be locked up, or she won't turn.
If my assumption of Blue + / Brown - is correct, I would assume that my oil pump on the main oil tank is bad. Can anyone confirm?
PN: 6E5-81900-01-00 / $156.19
