It seems side controls have positive neutral interlock, typically a button on the bottom of the shift handle that need to depressed before shifting out of neutral. Does anyone know of a binnacle style that has this same feature? This would be to replace a Yamaha 704 control, cable type for two stroke.
Binnacle control with neutral interlock?
Yes. Yup. That's exactly what the Yamaha binnacle has. But, regardless of brand, they all have some way of popping out into neutral. If not a button, then you slide the handle out/sideways. Other ones have a separate neutral handle.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by hevysrf1 View PostIt seems side controls have positive neutral interlock, typically a button on the bottom of the shift handle that need to depressed before shifting out of neutral. Does anyone know of a binnacle style that has this same feature? This would be to replace a Yamaha 704 control, cable type for two stroke.
"looks like" is a bad call. what you need is to match parts numbers of both units in relation to your powerhead
ÂÂÂÂÂÂÂÂÂÂ
