A while ago, with Boscoe's help (thank you!) I installed a simple vacuum gauge at the boat-mounted water/fuel separator filter head. It's screwed into the extra "out" port at the filter head. The reason was to check on the filter efficiency (clogged up).
It's been working great with typically less than 5PSI at idle.
Just recently, the OX66 250HP won't maintain WOT RPM - it will start to drop after about 15 seconds. It drops slowly/smoothly over the course of another 15 seconds or so.
I can maintain approximately 4,500 RPM just fine.
I noticed that the vacuum PSI at the gauge creeps up to about 15psi during this.
The gas is super clean in the boat - but I replaced the filter and the issue didn't change.
I tried running with the fuel cap off - no change.
I tried running with a portable tank hooked up to the filter head input - no change.
I'm stumped?
I'm stumped?
