Hi Team,
I've had this outboard for a few years now and it's never seems to run perfectly. The mains issues were it starting from cold, cutting out when put into gear and cutting out on idle. Some times we got all of them sometimes only one issue.
We have had it serviced but the issues were still apparent. I've recently changed the fuel pump, New fuel line and cleaned out the carbs. I've also installed a new kill switch. The petrol is fresh also.
To get it started now I have to manually open the carbs and it will run for around 30 seconds then die. The manual chalk won't do anything to get it started.
Just wondering where to start looking now?
Thank you in advance.
Jon
Jon
