Manual Relief Screw - Which way is manual
  • Manual Relief Screw - Which way is manual
    Sorry if this is a basic question but my manual just says to turn the screw to the manual position. Does the image of the motor tipped up signify manual or is the image of the engine in running position manual?
    It is turned fully counter clockwise so as to manually raise or lower the motor.
    The port into which your screwdriver goes usually has the direction marked on it to open the valve.
