Hello everyone, Thought I’d check in with y’all.
my 1992 Yamaha 40mshq was leaking out of the lower unit drain plug. When I removed it it wasn’t tight at all. I replace the black gaskets every time I change lube. I probably didn’t tighten it enough. I stopped when I hit bottom and I put a wrench on the screwdriver and snug it up. I do worry about over tightening.
I drained it and ready to refill. However I can’t find the torque value for those screws anywhere in my manual.
I have a little 1/4” drive torque wrench I could adapt a flat head bit to as well as a 1/2” drive torque wrench.
So far the 1/4” has covered everything on the power head.
Does anyone know if there is a torque for these screws or have advise on how I should tighten them properly without over doing it?
