Warning Buzzer At High Rpm's
  • fairdeal
    replied
    Originally posted by Res2que@ View Post
    I have the guages ...but there was no indication on them.....motors did not go into safe mode
    ....They ran perfect...other than the buzzer
    Are you absolutely, positively, 100% sure that it was the buzzer that you heard?
    so... some further development....the buzzer will come on at higher rpm's, but it come on and goes off at the roll of the sea...so when the boat goes up or down it the buzzer will sound with the pattern of the waves.....I know ...weird...any ideas???
    Also each key switch has a separate buzzer tone....but the tone of the warning buzzer is a higher pitch....
    Boats >26' are required to have a "bilge high water alarm"
    Do you know what yours sounds like?
    Leave a comment:
  • Res2que@
    replied
    yeah ...i tried that ....mechanic said it showed no code......guess ill try a different mechanic
    Leave a comment:
  • 99yam40
    replied
    on the F225 the oil pressure sensor is a sensor.
    it has a 5V reference and a ground with a voltage "pick off" to tell the ECU what the pressure is electronically.
    the ECU is also looking at RPM.
    the ECU is "mapped" so that at a given RPM the OPS voltage should be X value.
    if the value is higher OR lower than the RPM map then the buzzer is set and RPM reduction should occur if above about 2500 RPM.
    for temp the F225 uses two switch's AND a coolent temp sensor.
    if either temp SWITCH closes the buzzer will sound,after a delay, if the CTS agrees with the closed switch you get RPM reduction and a visual indicate.
    I don't design this stuff I just have to know how it works so I can fix it when its broke.
    incorrect battery voltage,water in the fuel(if equipped) low or high oil pressure,over temp can all set the buzzer on that motor.
    as you have been told before hook it up to YDS and run it until it alarms to see what it is seeing out of spec
    Leave a comment:
  • Res2que@
    replied
    Still buzzing ...
    Also each key switch has a separate buzzer tone....but the tone of the warning buzzer is a higher pitch....are there 3 different noisemakers ...or just the two behind the key switches....Thank you all in advance
    Leave a comment:
  • rodbolt17
    replied
    sensors fail, last one I did showed 140 PSI at 4200 RPM,alarm,RPM reduction and the oil visual lit up.
    its mapped target at that RPM is about 85 PSI.
    if you look at the manual for the F225 3.3L it will say low oil pressure on-variable with engine speed.
    the water detect was not an engine option on that model. it was however an option for the water separator in the hull. that's why I said IF equipped.
    they also break very easily
    instead of switch sheet simply run it until it alarms with YDS attached,hit save when the alarm is on and it saves the past 13 min of run time in 1 minute blocks.
    I like properly testing/trouble shooting. I DO NOT like switching things.
    Leave a comment:
  • 99yam40
    replied
    since he stated he did not get RPM reduction when the alarm came in at 4K that should rule out oil pressure.
    not sure about water in fuel cup as that is only in gear alarm but do not see how reducing RPM would make it go away.
    And I do not understand how voltage could change between 3200 and 4000 to cause the alarm .
    My bet is still on overheat that CTS and switches are not agreeing on
    Hooked up to a computer while it happens sounds like the correct way to see
    Leave a comment:
  • rodbolt17
    replied
    Leave a comment:
  • boscoe99
    replied
    I believe Rod has it, even thou I cannot remember what CTS is(some temp sending unit maybe).
    Possible you have some build up in cooling channels and running higher RPMs causes more heat then the cooling flow can remove closing a switch or water pumps need servicing.
    Or like the others have said oil pressure
    I think when he uses the term CTS he is referring to Coolant Temperature Sensor. Which really is not a sensor but a thermistor (heated sensitive variable resistor) with a negative co-efficient.
    If an oil sensor is not really a sensor, but rather is a switch, then a cooling sensor cannot be a sensor either. I suppose. grin
    Leave a comment:
  • 99yam40
    replied
    Leave a comment:
  • Res2que@
    replied
    Thank you i will try all that advice......im not sure what else the sound would be or could be other than an alarm boscoe....do you have an idea.....its a Grady 273 chase
    Leave a comment:
  • rodbolt17
    replied
    all F225 motors can be looked at with YDS they can also display active codes with the diagnostic test lamp.
    it may not STORE the code.
    the oil pressure switch can fail,it can be either low or over pressure.
    if either temp switch closes but the CTS is in range you get a tone with no alarm display.
    temp switch operation can be monitored with YDS, or a multi meter .
    Leave a comment:
  • boscoe99
    replied
    Leave a comment:
  • Res2que@
    replied
    If anyone has any ideas please let me know....Thank you for responding
    Leave a comment:
  • Res2que@
    replied
    Leave a comment:
  • Res2que@
    replied
    I had both motors checked at the dealer last week ...they ran a complete diagnostics and came up with 0 codes
    Leave a comment:
