Originally posted by DennisG01
View Post
But like you said, not re-usable...
Any kind (ever so slight) of air leak near the bulb, transom filter, etc WILL cause issues. While on my neighbors boat(200 Yammy), the engine wouldn't run without constant priming the bulb to get us home. Turned out to be the flat rubber gasket on the transom mounted fuel filter split, just enough to suck air and disable the engine. I just kept a pumping till we got home..(keep it clean guys..).
And the Yamaha brand primer bulb MUCH more expensive that the Seachoice, etc, you feel and see how much better made it was. (around $20.00 as I recall)..
Priced like G0ld
Leave a comment:
