Hi,
I have an issue with my old 2 stroke - 1997 Yamaha 70HP (70BETO 6H3). I'm hoping the community will have some ideas to help me troubleshoot the problem.
Background:
Motor was running fine until I ran out of fuel.
I swap the tank to a full one but the motor wouldn't start again and I had to get towed back to the ramp... The motor turns and fires but it stalls straight away.
Back at home, I had a look under the cowling and fuel was leaking from the bottom carb when pressing the bulb.
I don't think this is related, but I replaced the fuel line + water separator filter a few days before this happened.
What I tried so far:
- Checked the compression. It is even on all 3 cylinders but a bit low (80-75-75). That being said compression has always been pretty low (~90) in the 3 years, I've owned the boat.
- Installed new kit (gaskets, float needle) on all three carbs. When cleaning the carburetors, they were a bit dirty but I didn't notice anything major, except the float needle was stuck in the bottom carb, hence the fuel leakage, I replaced it with a new one. I didn't have a thin wall socket to remove the float seats so I just cleaned them without replacing.
The bottom carb doesn't leak anymore but the motor still doesn't start. You can hear it firing but it doesn't run.
Over the years, I've learned how to service the motor myself and do some basic repairs by reading this awesome forum and other resources but I'm not a mechanic and I'm not sure what else I can try.
Any pointers or suggestions would be very helpful.
Thank you!
Background:
Thank you!
