I have a 1991 225 yamaha. Tried to pull powerhead and broke off all 6 long bolts. What is the trick now to get powerhead loose
stuckpowerhead
The powerhead is stuckon my 225 1991 yamaha due to all six long bolts broke off while I tried to remove what should I do now.
I can't help, but a suggestion... You wrote three messages within just a few short minutes. You might not get too many people responding with that type of impatience. It's not like you're paying for advice, you know? Just a friendly tip!2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by DennisG01 View PostI can't help, but a suggestion... You wrote three messages within just a few short minutes. You might not get too many people responding with that type of impatience. It's not like you're paying for advice, you know? Just a friendly tip!
Not the first time that someone could not remove a block or a lower unit because of a fastener or two remaining. Those bolts are tough.
Originally posted by boscoe99 View PostHe was so busy writing messages that he could not check to see if all of the fasteners had been removed.
EDIT: Oh, I see what you're saying, now... there are MORE than 6. Gotcha.Last edited by DennisG01; 02-23-2015, 11:42 AM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
If the bolts broke off with lots of shank still in the housing and the corrosion inside there holding it , there is not much that can be done except drill/tear things up trying to get it all out.
I have seem people drill in from the side to cut bolts close to power head, pull the power head, and then beat the remains out of the housing
ÂÂÂÂÂÂÂÂ
