you need to figure out the software and set it up properly.
seems to me it thinks you have 3 motors and 2 think they are low on oil
2008 hpdi 300
It's just one 300 on a skeeter and it won't run if in the water not sure about the yds setup I just got it to see if there was any codes but I talked to a guy with the exact same problem and it was the pump in the vst so I will try that
Leave a comment:
I am really not much help on multiple rigged 300s,
but why is it saying some of the oil level switches show on and some off?
and why is this electric oil pump reading low?
I gather that this read out was while it was running on the hose out of the water.
is there something different when it is fired up while in the water?
in other words when the problem shows up
Why is there nothing showing of rail pressure on the last part?
Just you did not pick that to be captured?
Leave a comment:
1.Diagnosis Item Result Code Pulser coil Normal 13 Crank position sensor Normal 14 Water temp sensor Normal 15 Throttle position sensor Normal 18 Battery voltage Normal 19 Atmospheric press sensor Normal 22 Intake temp sensor Normal 23 Fuel press sensor Normal 25 Injector Normal 26 Water in fuel No 27 Shift position switch Normal 28 Engine stop lanyard switch Off 44 4.Engine Monitor Monitor Item (DATA) Result Unit Monitor Item ON/OFF Result Engine speed 825 r/min Firing of cylinder #1 Yes Fuel pressure (7.0±1.5) 6.66 MPa Firing of cylinder #2 Yes Fuel pressure (1015±217) 965.72 psi Firing of cylinder #3 Yes Atmospheric pressure 992 HPa Firing of cylinder #4 Yes Atmospheric pressure 29.4 inHg Firing of cylinder #5 Yes Ignition timing BTDC 3 deg Firing of cylinder #6 Yes Battery voltage (12-16) 13.77 V Starter switch OFF TPS voltage (0.5-4.5) 0.63 V Engine stop lanyard switch OFF Throttle valve opening (0-90) 2.7 deg Main switch ON Fuel injection duration 1.08 ms Shift position switch OFF Water temperature (below 90) 33 °C Water detection switch OFF Water temperature (below 194) 91.4 °F Oil level switch (remote tank) ON Intake temperature (below 70) 24 °C Oil level switch1(engine tank) ON Intake temperature (below 158) 75.2 °F Oil level switch2(engine tank) OFF Electric oil pump Low Oil level switch3(engine tank) OFF Water temp switch (overheat) OFF Dual engine system switch OFF Shift cut-off switch OFF 6.Data Logger [Data comparison graph] Time Unit Engine speed Fuel pressure Battery voltage TPS voltage Water temperature [r/min] (7.0±1.5)[MPa] (12-16)[V] (0.5-4.5)[V] (below 90)[°C] 20 min 500 6.61 13.48 0.66 47 19 min 1350 6.76 13.99 0.7 41.5 18 min 1450 6.71 14.43 0.84 47.5 17 min 1400 6.71 13.92 0.84 50.5 16 min 450 6.61 13.84 0.7 51.5 15 min 500 6.61 13.77 0.7 49.3 14 min 1200 6.71 14.21 0.7 41 13 min 900 6.66 13.99 0.7 49.3 12 min 1100 6.66 13.99 0.7 46.5 11 min 350 5.49 12.96 0.7 43.5 10 min 1200 6.76 13.99 0.68 38.5 9 min 1050 6.66 14.06 1.11 35.5 8 min 3350 6.71 13.92 4.16 49.3 7 min 3600 6.71 14.14 3.4 52.3 6 min 450 6.61 13.48 0.8 53 5 min 1050 6.76 14.14 0.63 23.5 4 min 900 6.71 13.84 0.63 34.5 3 min 900 6.71 14.65 0.63 43.5 2 min 750 6.71 14.79 0.63 48.5 1 min 1250 6.76 13.55 1.11 35.5 0.9 min 500 6.66 13.26 0.74 36.5 0.8 min 950 6.66 13.11 0.63 28.5 0.7 min 950 6.66 13.26 0.63 28.5 0.6 min 800 6.66 13.4 0.63 28.5 0.5 min 900 6.66 13.48 0.63 29 0.4 min 850 6.71 13.48 0.63 29.5 0.3 min 900 6.66 13.55 0.63 30 0.2 min 950 6.71 13.7 0.63 31 0.1 min 850 6.66 13.7 0.63 32
Leave a comment:
I have run yds and shows no problemsLast edited by Skeeter21i300; 02-16-2020, 10:55 PM.
Leave a comment:
2008 hpdi 300
ok motor has all new pistons i have 105 to 110 psi have not broke the motor in yet im back to my original problem of will not idle in water runs perfect on the hose i have replaced
bulb
in boat filter
fuel filter and water sep on the motor
both lp pumps
vst filter
had injectors cleaned
new plugs
new crank battery
im thinking computer but want to see what yall think before i spend 1500 on oneTags: None
Leave a comment:
