Will a lower unit from a 1996 50 hp bolt onto my Pro 50?
1992 P50TLRQ Lower unit
What are the part numbers for the two lower units?
Or use the information that is available to you at this website per the Yamaha parts catalog.
http://www.boats.net/parts/detail/ya...300-12-EK.html
Thanks for the reply. I did do a search and unfortunately the numbers are different. I was hoping to find out if even though the numbers are different does that mean they won't work? Are the mounting holes the same? driveshaft the same? That is the kind of info I am searching for.
Thanks again
Looking at the parts fisch, there's a long shaft and a short shaft lower unit option...
Did you click on Boscoes link?
It says ALL the engines that lower unit will fit..Scott
Originally posted by cbreeze18 View PostJust went back and looked at Boscoes link. That is exactly the info i was looking for. Thank youScott
ÂÂÂÂÂÂÂÂÂ
