If it is not a meter made for these ignition systems then you will need a DVA adapter to hook up the meter to
Yamaha 40 run for 30-33sek and stops!!
Now I have the engine running for idle as long as I want, but I haven't tried to put the boat in the water yet.
I had forgotten to connect the upper thermo switch, but when I connected it the engine did only run for 2seconds so I bought a new one but same thing
The engine would only run for 2seconds.
Then I took the orange / green wire from the cdi box and grounded it.
ÂÂÂÂ
