This post is in response to "Pablo" in San Antonio - he has a Yamaha 130 (V-4 block) that is sounding the alarm when rpm gets over 4000:
The cooling system has basically four parts to it:
1 - the water pump
2 - the water jackets
3 - the thermostats
4 - the pressure control valve (aka pcv, pressure relief valve (prv), poppit valve)
Pablo's motor is sounding the alarm anytime he runs over 4000 rpm - so it sounds to me that the motor is overheating, i.e, one of the thermoswitches is closing.
1 - the water pump could be weak and not providing enough water pressure to cool motor properly - if no pressure gauge and it has been at least three years since last wp repair, then needs to be done.
2 - water jackets could be clogged with mineral deposits/debris. Flush with Salt Away or Salt Terminator. Or may have to remove heads and clean out.
3 - the thermostats could be clogged and not opening properly. Remove and inspect/clean/test per the manual to verify opening to 0.120 inch at approx 135 degrees f.
4 - the pressure control valve could be stuck open and allowing cooling water to pre-maturely dump out the relief holes. Remove and inspect/clean. There should not be but a trickle of water coming out the relief holes under normal operation. The pcv is designed to open at around 20 psi to relieve over-pressure in the water jacket.
If all of the above is working properly and still getting overheat alarm, then pull the thermoswitches and test them per the manual. They should close at around 180 degrees f. and reopen at approx 160 f.
Also, a blown head gasket could cause overheating - check compression on all cylinders.
They should be within 5% of each other.
Pablo, I think I have covered everything here that could lead to your overheat problem - let us know how you come out.
Ken K
1 - the water pump
3 - the thermostats
Ken K
