Shift postion switch
  • boscoe99
    replied
    If any switches do have a resistor, think Yamaha is going to be telling anyone which is which?
    Leave a comment:
  • fairdeal
    replied
    some have resistors built in.
    guessing that is parallel to the contacts - so the ECU can distinguish "disconnected" from "open" ?
    Leave a comment:
  • rodbolt17
    replied
    and not all shift cut or position switchs are simply on or off. some have resistors built in.
    Leave a comment:
  • fairdeal
    replied
    the "neutral start switch" in the remote control is in series with the cranking "signal" -
    all it does is enable/prevent the starter from running.
    The ECU has no knowledge of its state.
    the neutral switch at the engine is an input to the ECU
    should be closed (continuity) when shift lever is in neutral
    open (no continuity) when shift lever is in gear.
    I think - but not certain - that the neutral switch is the inner one, with the shift cut switch the outer
    per the wiring diagram,
    the harness lead for the neutral switch has a black and a brown wire
    the harness lead for the shift cut has a black and a blue/yellow
    Leave a comment:
  • Keith Ohanesian
    started a topic Shift postion switch
    What is the best way to check the switch on the engine and the one in the controls?
