My engine is starting to idle at or around 900 -1000 out of gear. If i shut it off and start it again once or twice it might go back to 700. Smells rich and I'm lost. Any suggestions?
f225 txrd high idle
ah rightOriginally posted by rodbolt17 View Postwere all the throttle link updates done?
2002~2005 F225, LF225, F200, and LF200
FACTORY MODIFICATION CAMPAIGN - THROTTLE LINK RODS
Yamaha Technical Bulletin O2004-010
Given that the problem seems to be described as intermittent,
I suppose that "mechanical" issue is more likely that a "bad" or disconnected sensor
Keith, you can call Yamaha Cust Service in Georgia - 866-894-1626
and they will look up to see if the recall was done on your engine
It's showing irregular and had a stored code for the shift position. The throttle linkage has the bumps on the top. I don't get why it's idling crazy. Start up the engine cold and it idles at 600-700. Shut it off while at 150 and start it again. It can idle at 1100, 900, 800,or 700. At 600 and 700 the timing is around 2 degrees and at 900 and 1100 it's about 9 degrees. Thats whats showing on the yds. The engine will reach 6000 at 50mph.Originally posted by rodbolt17 View Postgo over to the screen labeled diagnosis.
if a signal is bad or irregular and active it will be at the top and high lighted. stored codes will tell the engine hour it got stored.
