I'm not a electrical guy, so the whole rectifier charging system is kind of muddy to me. I've got a 2006 8MSH as a kicker motor and I'd like to power my fishfinder when *****ing long days. So I'm really only looking for 2amps, since I know these engines don't put out much.
As is, I looked at the schematics and I have the 2 green wires, both with female connectors, coming off the Lighting Coil Assy. When checked with a volt meter, in DC, the readings are all over the map. There are also several wires coming off the charge coil and pulser coil but they are not open connections.
Can anyone give me the quick run down on which wires I need to tap into and/or if I need an additional rectifier? I don't see a rectifier in the "Optional Equipment". I found a "common" wire color code for Yamaha engines but it talks about High Speed and Low Speed Charge Coils and the green wires seem to be Lightning Coil Leads.
Sean
Sean
