I recently cleaned all the carbs and installed new carb kits. I was going through the link and synch procedure described in Clymer's manual. I set the static timing as described. However, when i went to check the ignition timing (with light), it was way off at 12 degrees ATDC (should be 6-8). Motor, of course, ran horribly. So to get the measured timing at 6-8 ATDC i had to adjust the static timing in such a way that the throttle arm indicators no longer line up where they should on the electronic timing cover.
What would cause this discrepancy? After adjustments motor runs much, much better.
