hello i have a 1990 cv85etld yamaha outboard. im putting in new thermostat in. could u tell me what the torque is on the 4 bolts. in ft lbs or kgm. thanks
torque question
Originally posted by Sequoiha View Postif memory serves me right, im thinking about 40 inch lbs. i usually just take a regular 1/4 inch rachet and tighten them equally..
anode
thanks for reply. same 1990 yamaha cv85etld. im wanting to inspect the anode also. from looking at the cylinder crankcase diagram & my motor there is a bolt 14mm in size located between 1 & 2 cylinder to the left a little. i see its inside . is this difficult to change anodes out or if i unscrew the oval head screw can it fall down inside? ive worked outboards for years. never have put a anode in. thanks for any info
ÂÂÂ
