Can one use injector cleaner with a two stroke motor?
Injector cleaner
You really shouldn't use fuel injector cleaner. It sometimes will do more bad than good. You should pull your injectors and send them out for reconditioning. You also want to make sure the fuel in your tank is good, clean the filter in the VST, and replace all of your fuel filters before you reinstall the reconditioned injectors. If you are looking for a place to send the injectors, we flow test and recondition them for $20 ea. Let me know if I can help.Tom
Accurate Fuel Injectors.com
ÂÂÂÂÂ
