Do you need to defog these engine if I put oil in the fuel filter and run it?
winterizing two stroke hpdi
Better to remove spark plugs and put about an ounce of fogging oil in each cylinder, then pull landyard cord and spin engine over with starter to coat cylinders with oil.
Probably, that's why you need to pull the 02 sensor every season to clean and test. Do this AFTER you fog. May want to drain the VST also. AND that high pressure pump might not take kindly to straight oil.1999 Grady Sailfish SX225 OX66
ÂÂÂÂÂÂÂÂÂ
