Steve,
Yeah, when up on plane and WOT and trimmed out, take a look at the cavitation plate. On my Pathfinder, there is a recessed area at the bottom of the transom, a type of pocket area that allows the water to "swell up" when up on plane. With the motor trimmed so that the cavitation plate is parallel to the keel, the plate is actually about two inches higher than the keel. But because the water "swells" up from the effect of the pocket, the cavitation plate rides just on top of the water surface when on plane and trimmed out and WOT. This is what you are looking for. You may well indeed need to raise your motor one notch up.
I've never had to move my outboard up or down - but I think what Whitedog suggests might work - except that I would try to support some of the weight with the cavitation plate also, not just the skeg. An engine hoist would be ideal.
Yeah, "post Rita" is still going on - have been rebuilding the wooden fence now for the last two days - if the wind lays tomorrow, I'm gonna sneak off and go fishing [img]smile.gif[/img] .
Whitedog,
The performance data that you quoted is interesting - but I believe 5600 rpm for the 90 Yamaha is 100 rpm over max - does it make a difference? I don't know - but personally, I prefer to keep my rpm max at the mid-range for what Yamaha recommends - 4500 to 5500.
On Boating Life's test boat, were they running a full tank of gas with two persons and a full load of gear? That extra weight could make a big difference.
Ken K
Whitedog,
Ken K
