I have (2) 2004 Yamaha 225 HP Four Stroke engines. They use to go 6000RPM at full open throttle,but now the right engine will get 200-300RPM less than the left one. Both engines start and idle perfectly. There is no misfire or vibration. Can someone please tell me how should I diagnose the problem? Is it possible to do some test without having to plug-in a computer like the Yamaha dealer use to diagnose the engine. THANK YOU!
Lower RPM in the RH rotation engine
Check condition of prop, check throttle cables and linkage for wear.
Thanks,i will inepect the prop and check the cable/linkage this weekend. Will let you know the results.
engine
+1 on the above..
I would also check the throttle linkage on the engine (turned off) and compare it to the other engine and make sure the throttle plates are opening fully (the same amount).Scott
ÂÂÂÂÂÂÂÂÂÂÂÂ
