Quick question, i have a 07 yamaha 90 two stroke and have a harness not plugged in. It has a green, green/red stripe, grey, and pink wire into a 4 pin harness. Is this normal not to be hooked up to anything. Also, is there anyway to test to make sure my buzzer/alarm is in working condition.
2007 yamaha 90
If its an off white colored square connector then that goes to the yamaha gauges with warning indicators, engine warning system will still work with or without gauges installed.
to test the alarm you might try pulling the kill switch off and then turn key to on, I believe that should cause the buzzer to sound
Thanks for the response, that resolves the plug issue.
Tried the kill switch with key on and no buzzer, any other
Ways to check?
If have the Yamaha switch panel with key switch and landyard on panel then the landyard disconnect alarm will activate when turn key to start position, when engine cranks over the alarm should come on. If switch panel does not have landyard included may not get the alarm.
On the two stroke models can ground the pink wire of temp sensor on cylinder head and turn key to on position to activate alarm.
ÂÂÂÂÂÂÂÂÂ
