Can anyone tell me if the wiring harness on my motor has a plug to hook a Tilt/trim switch to the cowling ??????????? Thank You
2000 90 hp 2 stroke Yahama
looks like you should, is there a hole in lower cowl ??
6H1-82563-10-00 YAMAHA TRIM & TILT SWITCH $54.30
47 6H1-82563-10-00
TRIM & TILT SWITCH ASSY
FOR 90/90JET (6H1)
$72.40 $54.30
90 2 Stroke
No whole in the cowling, but there is a place inside the cowling for the bracket to hold the switch in place. I will have to drill a whole for the switch. I have the switch I just don't know how to wire it to the harness. There should be a plug on the wiring harness, but I can't find it???????????????
Thank You
Touche Cape Coral
Follow the blue and green wires from the PTT motor to the PTT relay. The wires for up and down control will also go to this relay. Follow these wires and see if there is someplace where they connect to the main harness, usually there is, if not make a jumper connection.
ÂÂÂÂ
