It has A new oil float sender and control unit with manual switch, it will pump when switch is applied, but not auto with motor running,I am also using A known good remote tank and harness for testing purpose, I am not getting the needed ground circuit from the blue wire on the engine harness that I get when the pump runs manual. CDI unit ?
130 TLRY not pumping oil to motor tank
Chech grounds at oil control unit. With new style oil control unit engine gas to be running to operate oil transfer pump.
OilTransferChart.pdf
do a search for some older posts by Rodbolt, he has explained this in great detail, how it works and how to trouble shoot.
ÂÂÂÂÂÂÂ
