2007 V150 2 stroke VMAX. On the lower unit there is a small stainless steel wire strap that goes from the lower unit to the bracket that mounts the tilt and trim unit. Whenever the T&T is in "use" the wire becomes extremely HOT. T&T works fine with it connected or not. Any idea what's causing this?
Hot wire
You have a bad ground somewhere, check all ground wires on engine.
Originally posted by boats.net View PostYou have a bad ground somewhere, check all ground wires on engine.
today i could not raise or lowermotor w/ o doing it manually.
what is the best sconomical path to get this done?
my car mech, buddy took off the motor assembly for me
ÂÂÂÂÂÂ
