Wher can I purchase shop manuel for 2005 f 150 four stroke
Shop manuels
YAMAHA MANUAL STORE
This will give you the info you need and then you can do some searches for that part number to see what you can find
Did you check with a meter to see where you were loosing the voltage like a mentioned? If voltage is coming back after just bumping the starter by shorting across the start relay, then I would be looking at the connections at the relay
ÂÂÂÂÂÂÂÂ
