I have a 1987 115hp Yamaha on my 18' Boston Whaler that has run like a top until this weekend. After trailering our boat approximately 5 hours for a camping trip and then running the boat at 3/4 throttle for the 6 mile cruise to our island getaway the engine stalled the moment I backed off the throttle and reduced to idle speed. Then the engine was nearly impossible to start...and when I could start the engine I could only keep it running with a high choke. The moment I reduced the choke to shift into forward (or) reverse gear the engine stalled. A local mechanic looked very quickly at the engine for 15 minuted to see if this was as easy fix and he confirmed the following:
1. Fuel pump was delivering fuel as the plugs were wet and the carb had good clean fuel;
2. Plugs had good spark;
3. Engine had good compression at 117 in all cylinders;
4. Fuel filter on engine was clean;
5. Water separator (cannister style) was clean without any water.
What do you folks think is my problem? Carb problem? Fuel pump? Coil? CDI?,,,,?
The engine has been used a couple of times per week (2-3) alll summer without any problem and as a result this problem was a huge unexpected surprise.
Thanks in advance for any feedback or tips.
