bottom two carbs on 100hp 4strock froze up motor hasn,t been used over one year
old gas causing the carbs to not funcion. have taken carbs apart and cleaned the floats ect but will not funcion at low rpm. top 2 carbs work fine suggestions.
hey buddy from what you or saying your float is damage and it is causing your carb to flood rebuild your carb and it should fix the problem good boating
