I have a 1991 200 Pro-v Yamaha.
I have had constant problems getting the engine to run correctly.
I will hammer the throttle out of the hole and some days it will only rev to 2000rpm.
Other days it will pull to 5200-5400 rpm and stop revving just like there was a brick under the throttle.Engine is not over propped with a 21 pitch Rev-4 4 blade.Engine idles excellent!
I rebuilt carbs last year.
Engine has 150 lbs compression across the board.Custom heads.
Replaced both fuel pumps 2 years ago.I have checked them and they DO NOT LEAK.Clean fuel filter.
New gas lines 2 years ago.
Ignition set at 22 BTDC and 6 ATDC at idle.
I am begining to wonder if I need to look into the ignition system???
Any suggestions would be greatly appreciated.
Thankyou
Thankyou
