Need Help Yamaha 225 Four Stroke
i Have A 2005 Yamaha 225 Four Stroke Engine,when I Take Boat Out Starts And Runs Fine Till I Get To Fishing Grounds,turn Of And Drift When I Restart ,it Starts But Sputters And Power Is Normal And If I Increase Rpm To 900 Or Better Seems Fine,when I Return To Port And Try To Go Slow Down Canal Seems To Idle At Bout 500 Or 600 Rpm And Really Sputters And Shakes,have To Bring Idle Up To 900 And It Clears Up,any Help From Someone With Experiance Would Be Greatly Appreciated,,am Mechanic But Not For Boat Out Boards Thanks Tom
Tags: None
May need to test idle control valve and check throttle position sensor setting.
