I have a 2002 yamaha vx250 and the over heat alarm went off today. it was a steady alarm. I just had the water pump and impeller replaced in jan, 2010. I was woundering what could cause the alarm to go off? Thanks in advance.
overheat Alarm
i replaced that filter in feb. of this year, could this still be it? I was also told to replace the impeller again but i was thinking that if it burned up after 5months there must be something else going on but i am no mechanic thanks for the response.
The alarm will go off if overheats or oil level low, the water in fuel will only go off when in neutral. If you know it's the overheat alarm then start with water pump, check thermostats and pressure control valve.Last edited by boats.net; 05-17-2010, 07:15 PM.
Originally posted by boats.net View PostThe alarm will go off if overheats or oil level low, the water in fuel will only go off when in neutral. If you know it's yhe overheat alarm then start with water pump, check thermostats and pressure control valve.
ÂÂ
